Guys,
Two questions. First, I’m wrapping 10 PT6x6s for a screen porch addition. The columns will be 10×10, so I have to build up each 6×6 with some blocking. There will be railing and spindles attached to the posts. Does Azek have the structural strength to brace the railings or should I wrap the posts with Windsor One type wood. Second, if I use Azek to wrap, can I pocket screw and glue butt joints (flush trim with a router) or do I have to miter? Everything will be painted.
Thanks in advance. I’ve read alot but never worked with PVC trim.
FR
That is going to cost quite a lot in Azek. You'll need to make them a little larger than the 6x6 to account for the expansion/contraction. Do you really need to use one of those two products? My first choice would be fiberglass column, you can get them in all sorts of styles, they're structural, quick, take paint very well, will take dings and such better than anything else and they'll be the same cost or cheaper than Azek.
Great thinking-But given the either, or, I'd go with the Azek, I just plain like the stuff.
I like it a lot too and use it over wood quite a bit but in this situation the fiberglass is a no brainer to me.
DDay,
I didn't even consider fiberglass because all of the discussion seemed to be around PVC or engineered wood. I just checked a website for pre-made column wraps and a 10"x10" x 9 foot column wrap was about $300 for fiberglass and $200 for PVC. Fiberglass is structural and PVC is decorative. Is the consensus that, even primed and painted, engineered wood (like Windsor One) on a screen porch is a bad idea from a maintenance perspective?
I just always look for no or the least maintenance. Even if it's more money, I think about having to fix/paint or whatever down the line.
Yup.......
Ditto on that!
I would go with the Azek. If you are blocking the 6x6 put some directly behind were the railing will attach and that will take care of your structural concerns for the railing. I normally assemble box columns like that with simple butt joints tacked first and then stainless trim head screws.
Thanks CIM.
FR
