Any idea how to fix a warped hard board hollow core?
There's a constant source of clean water for you to use, and all you have to do is collect it.
try laying it in the sun (convex)....check reg
*Or for even more correction, put it concave side down on the grass in the sun. The small side will expand due the moisture from the grass the large side will shink as it dries out. But unless you secure it in its new shape, it may just return to its current shape when the moisture equilibrates again. Don't new hollow core blanks come pretty cheap? -David
*Buy a new slab for $30.00
*Shan, If the door was properly sealed (primed both sides and all edges) within a week of delivery, the manufacturer will usually replace the door under warranty. Check with the supplier.
