Anyone know the name of the plastic sheets that are used for water proofing basement walls. I belive they are corrugated on the wall side. I’ve done interior perimeter drains before with great sucess (after eliminating outside causes). These would be used when you break out the slab around the perimiter. They’re placed against the wall and channel H2O between slab and wall to the drain. Thanks
