ballusters required for stair railing
EricBrewer | Posted in General Discussion on June 20, 2008 03:45am
Hello Everyone,
Are vertical balusters required for the stair railing on a deck?  It is 14ft long and 8ft high. I was planning to just put up the posts, a top grab rail, a middle rail attached to the sides of the posts, and maybe a bottom rail.
Thanks! Eric
  1. ChicagoMike | Jun 20, 2008 03:47am | #1
    In NY, yes. No more that 4" apart.
    "It is what it is."
    1. EricBrewer | Jun 20, 2008 03:48am | #2
      should have mentioned this is Vermont. Don't know if it matters.
        Matt | Jun 20, 2008 04:05am | #3
        Generally balusters are required if the walking surface is greater than 30" above the surrounding grade.  For something 8' high, not meaning to be rude, but common sense aught to tell you what you need to do - unless your friends are coming over with those bratty little kids that need to be disposed of anyway... ;-)
      2. VTNorm | Jun 20, 2008 01:51pm | #9
        Eric - depends where in VT. I'm in the Benningtn area and there are no inspectors in most towns and no one cares at the local/state government level. However, I have had to add balusters due to homeowners insurance companies demanding it.
        Check with your local town hall and your insurance company.
        -Norm
  2. RedfordHenry | Jun 20, 2008 05:39am | #4
    I'm guessing that you don't have any kids.  If there's a hole big enough to fall through, it's just a matter of time before some kid does.  I'd go with the ballusters.
  3. MSA1 | Jun 20, 2008 05:42am | #5
    Where are you? In Michigan they are required. I'm pretty sure thats standard in the code book.
  4. Dave45 | Jun 20, 2008 05:49am | #6
    Eight feet above grade?  Almost certainly a railing and ballusters are required.
    Your local building department can give you their requirements, but here in San Jose, CA, any deck or porch more than 18" above grade must have a rail at 36" with ballusters spaced so there's no more than a 4" opening between them.
    Ted W. | Jun 20, 2008 07:54am | #7
    In Chicago, no opening more than 4" at it's widest point. I'm guessing similar rules apply in your area and just about anyplace else.
    Cheap Tools at MyToolbox.net
    See some of my work at TedsCarpentry.com
    1. EricBrewer | Jun 20, 2008 12:06pm | #8
      I am in vermont and have balusters on the deck itself.  I have young kids and have a child safety gate at the top of the stairs so the kids can't use the stairs.  Was wondering if I could skip the vertical  balusters on the stairs and essentially use "horizontal" balusters (2x4's along the length of the stairs, attached to the posts).  Have seen several others like that around here, but wasn't sure of code.
      Eric
        Matt | Jun 20, 2008 01:54pm | #10
        Regarding "The code" - there is no universal code for all states....  So really you need someone from your state, maybe even your town or county to answer the question.   The best thing is just to pick up the phone and call your local building inspections department.  Even if building code is not present or enforced in your locale you still could be held liable if an accident were to occur.
        This web page says "ICC INTERNATIONAL BUILDING CODE, 2003 EDITION - AS AMENDED" is used in Vermont under "adopted codes".  The "AS AMENDED" is the reason you need a local resource to get a definitive answer.
        Regarding horizontal balusters - some codes specifically prohibit these as kids can climb on them - essentially using them as a ladder.
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
