I was wondering what techniques you guys use to lay base molding where the carpet is a bit higher then the connecting floor. Do you build up the lower side? put in a connecting piece? or?
Thanks,
Steve
Thanks,
Steve
This thoughtfully designed home preserves the character of its neighborhood while maximizing space for a growing family through careful attention to scale, rooflines, and material choices.
Do you only lay molding on perfect floors or did I just get lost in Prospero land?
Or if I'm banded for bad behavior let me know. LOL
If it wasn't clear here is an example. Living room with carpet meets kithen with vinyl. Carpet is about 3/8 in higher than vinyl. Need ideas to make the base molding fit this hump. I thought about a 2 piece over the vinyl but then I'd have to do the entire kithen that way. So looking for a transition idea.
Thanks,
Steve
Sorry Steve, I had expected the veterns from your area to leap to your aid here.
The practise I most often see/do around here is where the base goes in at the same height; but, a hard floor like vinyl, tile, wood, cork, ... has a shoe (actually, around here it's most often 1/4 round, but I hate the look of 1/4 round and much prefer a thin profiled shoe) to cover the gap.
I have been asked to do height transitions, usually in the 1/4" - 3/8" range and have done that with a really lazy "Z", roughly 1' - 2' in length with all but the last inch or so on the carpet side, then cut the bottom of the base to clear the carpet, but make sure the bottom of the base is compressed into the carpet (i.e. you can't really see the bottom of the base) as you approach the hard surface. IMHO, when the transition piece is over the hard surface, it sticks out like a sore thumb; when it's over the carpet, you'll only notice it if you know it's there. The trick seems to be to place the transition piece away from any hard planes that will draw the eye/give it away..
Phill Giles
The Unionville Woodwright
Unionville, Ontario
Thanks Phil. Did you mean 1 to 2 inches in length? I understand what you mean but I'll have some fun cutting it so that it fits good.
Steve
No, feet, the turn is 1ยบ, you can hardly see it - not that much different from Mr. T's solution..
Phill Giles
Unionville, Ontario
Steve, How much will the carpet compress?
See how far you can push down the base on the carpet side.
If you can't get the base all the way down to the vinyl the make a notch and a loooong taper on the transition piece.
then just continue around the carpet with full size pieces.
If you make the taper long enough no one with even know it is there.Mr T
Do not try this at home!
