Using 2×4 framing against the outside poured basement walls as basis for
wallboard or paneling, with isulation between the upright studs. Is the use of 24″ on centers OK?
Jim at [email protected]
Hi Jim,
Using 2x4's in a 24" o.c. scenario seems to be more of an aesthetic question in your situation than a structural one. I say that because I assume that the wall-to-be will be non-load bearing. If this is the case, then the decision is alot easier. But you need to realize that the finished wall material will be twice as suseptable to move (bow) under load. Just take a glance sometime at a wall with 1/2" drywall on it that was framed this way, from a low angle...the drywall "washboards". I have had the opportunity to frame on 24's many times and have always opted not to. If you feel pressed in the favor of the 24" o.c., by all means, use blocking in between. Or if you are going to panel, (material not specified) you really should fur it out. aka horizontal strapping. But then, what have you saved?
*Hello Jim,I'm with Huntman on this one.More often than not, 24 o.c. willtelegraph through the material itwas covered with. 16 o.c. willgive you more fastening optionsfor trim, cabinets, etc.Mike Merisko
Using 2x4 framing against the outside poured basement walls as basis for
wallboard or paneling, with isulation between the upright studs. Is the use of 24" on centers OK?
