I just moved into a 6 year old cape outside Reading, PA and the previous homeowner had installed fiberglass insulation with the fiberglass side exposed into the basement. I am putting a woodworking shop in the basement and don’t want to be breathing all of the fiberglass. (sawdust is enough thank you) Do I really need this insulation (we haven’t lived in the house long enough to know how cold it gets in the basement in winter) or can I turn the insulation around or cover it with craft paper? I want to do something quick because every time I go down there now my sinuses go into overdrive. thank you in advance for any advice you can provide.
Your sinuses may not be in overdrive due to the fibrglass. It could be mold, mildew, etc. from the basement being damp.
Insulating the floor is a complete waste of time. The basement is inside the house!!! Please treat it as though it is inside the house!!
I would leave it in, or perhaps add to it for some minor measure of sound attenuation.
Throw some drywall up.
-Rob
*Thanks Rob, I wish I could say it was mold but it is actually quite dry in the basement.(well dry as basements go anyway) what I have noticed is whenever my 4 year old runs across the living room floor you can see the fiber (or dust) literally falling from the batting (the stuff lights up pretty good in the light)
*#1) I'm just a homeowner,so take this for what it's worth. But at my mom's place, we had the same issue. Stapled some clear poly sheeting to the bottom of the floor joists. Worked like a charm. Cheap and effective.
I just moved into a 6 year old cape outside Reading, PA and the previous homeowner had installed fiberglass insulation with the fiberglass side exposed into the basement. I am putting a woodworking shop in the basement and don't want to be breathing all of the fiberglass. (sawdust is enough thank you) Do I really need this insulation (we haven't lived in the house long enough to know how cold it gets in the basement in winter) or can I turn the insulation around or cover it with craft paper? I want to do something quick because every time I go down there now my sinuses go into overdrive. thank you in advance for any advice you can provide.
