basement refinishing
user-127528 | Posted in General Discussion on March 22, 2006 03:37am
I am remodeling my basement and I am unsure as to how to proceed.  The past owner studded up the walls and put styrofoam between the studds and drywalled over the top of that. I have mold on my walls that I now need to get rid of.
If one studs the walls, how do I proceed so that I won’t get that mold back again. I have looked into “closed cell insulation” and I have also had someone talk to me about a total plastic remodel. It sounds good but looks well plastic.
I can use any help at this point that I can get. The Shadow
    loucarabasi | Mar 22, 2006 03:57am | #1
    shadow, use metal studs and keep at least 2inches from foundation wall and metal stud wall this will allow air to travel behind wall and dry out any moisture, plan on using a dehumidifier too. Use rigid insulation between the studs, Just keep that air flowing behind
    Hope this helps, Lou
    1. user-127528 | Mar 22, 2006 05:08am | #2
      On the insulation How about using close cell spray in foam insulation?
    JDRHI | Mar 22, 2006 05:54am | #3
    My first concern would be getting rid of the moisture.
    Do you know where its coming from?
    J. D. Reynolds
    Home Improvements
    1. user-127528 | Mar 22, 2006 06:51am | #4
      Normal basement with a normal humidity. I think that is what caused the mold on the walls. The drywall didn't have any and the styrofoam had it only where it touched the wall and then only in spots. I haven't gotten all the outside walls down so I can't say how widespread it is. This is why I am trying to find out how to refraim my basement.
        JDRHI | Mar 22, 2006 03:43pm | #5
        ...the styrofoam had it only where it touched the wall and then only in spots.
        By, "the wall", I'm assuming you're talking about the foundation wall.
        If that is indeed the case, and it holds true once all of your walls are open, the first thing you'll need to do is seal the foundation walls. There are several products on the market....availability may be regional...check into which ones you can get in your area.
        Once you're sure you've conquered the moisture problem, you can begin framing. As others have mentioned, framing with metal and leaving an air space between perimeter and foundation walls is you're best bet. (Be sure to fireblock the opening behind wall at ceiling) Ridgid insulation....moisture resistant sheetrock...galvy drywall screws...mold/mildew resistent primers and paints and of course a dehumidifier.
        Above is rather general....feel free to inquire about specifics.
        J. D. Reynolds
        Home Improvements
Outdoor Lighting
