I need to locate a company that manufactures a self contained toilet that can be installed in a basement or any room where there is no plumbing below grade. I am able to run the discharge pipes overhead. I’ve seen them advertised but can’t find one when I need one. The particular model I’m looking for has a sewage pump installed in the unit. The toilet sets on the holding tank. Any help will be appreciated. Dale from Michigan
Learn about balloon-framing construction techniques, including stud patterns and efficient assembly methods with minimal manpower and scaffolding.
home depot has or can get them, so a good supply house should also have access to them.
*I haven't tried these, but I was looking for something similar recently & came accross this site. They advertise in FHB.http://www.saniflo.com
I need to locate a company that manufactures a self contained toilet that can be installed in a basement or any room where there is no plumbing below grade. I am able to run the discharge pipes overhead. I've seen them advertised but can't find one when I need one. The particular model I'm looking for has a sewage pump installed in the unit. The toilet sets on the holding tank. Any help will be appreciated. Dale from Michigan
