Basement window install new foundation.
andyb | Posted in Construction Techniques on July 24, 2006 07:38am
Stupid question maybe.  Is it ok to install 15″ tall basement windows with their top edge even with the top of the foundation wall.  In other words, only the mudsill acting as a header for the window?  Thanks.
  1. andy_engel | Jul 24, 2006 11:22pm | #1
    Yep, usually. If you're nervous, connect the joist that falls over the window to the rim using a joist hanger. Make sure the rim doesn't break over the window. In most cases, a single 2x10 or 2x12 can handle the load of one or two joists. If you've got a point load or a really wide window, double the rim over the window, and then use joist hangers.
    Andy
    "Never try to teach a pig to sing. It wastes your time and annoys the pig." Robert A. Heinlein
    "Get off your dead #### and on your dying feet." Mom
    1. andyb | Jul 25, 2006 02:07pm | #2
      Thanks Andy, exactly how I was thinking of doing it.  Sometimes you just need to hear things from somebody else.
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
