Basemwnt Walls
Hammered | Posted in General Discussion on July 18, 2005 04:22am
I’m planning on using Drylok on my Basement walls. They’re Concrete Block.
They were painted 30+ years ago. The bottom 4 courses are flacking and won’t be hard to remove. I’m planning on using a pressure washer. Will a pressure washer remove the old paint from the top 4 courses?
  1. sledgehammer | Jul 18, 2005 07:44pm | #1
    A pressure washer will remove any paint that  has less adhesion then the washers pressure.
    Unless you have solved the hydrolic pressure problem the new paint will start flaking shortly.
  2. csnow | Jul 18, 2005 11:13pm | #2
    A powerfull pressure washer will cut into the blocks themselves, if you want it to.
    I recently used one to remove mortar for repointing stones. The stone wall had also been painted, and the paint came off with no trouble at all.
    1. Hammered | Jul 18, 2005 11:40pm | #3
      Sounds like a plan. What kind of psi were you running? Or Horsepower of unit?
      1. csnow | Jul 18, 2005 11:54pm | #4
        That was a 4000PSI unit.  Rented it. Can't remember the HP.
Drafting the 2027 IRC
  • The New Old Colonial
