beef up a 4″ slab
ganjo | Posted in Construction Techniques on January 24, 2006 04:00am
We are putting an addition over a garage. The edge of the existing slab needs to be beefed-up (replaced?) to support the new load above. I’m sure this has never been done. What is the best way to do this?
  1. boulderbuilder | Jan 24, 2006 04:25am | #1
    it's called underpining and your engineer will call out the details, locations, etc.  of the suplementation depending upon your soils report and designed loads.  there is very little for you to do at this stage other than choosing a qualified engineer and architect.
  2. ponytl | Jan 24, 2006 06:57am | #2
    your engineer could have a few options...
    a grade beam
    load bearing posts where only the post pier has to be placed... and the post will carry most of the load
    just a couple options to ask about...   i usually design what i believe will work  often designed around materials i have or have access to then ask the engineer 'Will this work"  usually i have overkill in my design  but i can usually do mine faster & cheaper... i always ask
    p
