Mounting some of DW’s arty tile groups for sales (usually six 6×6 or 8x8s) on a piece of ply with mastic, with about an inch of extra all the way around to attach to a frame; all this to hang on a wall. No grout; tiles are mounted edge-to-edge.
What’s the best permanantly non-warping material? Approximately 18 x 26 X 5-8 – 3/4″” at maximum. Ply might eventually bow a bit; OSB? MDF? MDO? Melamine-faced OSB (both sides)? Baltic-birch ply? 1/4″ Hardi-backer on melamine?
DW really wants to know. I had one piece of OSB from a sample of Dri-Core for the first one; it’s supposed to be a moisture-resistant OSB under the plastic waffle surface.
Help me, Obi-Wan-Kenobi –
Bumpingness
I would use the baltic birch plywood.
And get back to work.
One factor: "duplicate" whatever is done on the front on the back so any warping tendencies from the front side will be cancelled out
"Ask not what the world needs. Ask what makes you come alive... then go do it. Because what the world needs is people who have come alive."
Howard Thurman
Wait - tile the back, too?
