I am building some bookshelves with MDO. What will be the best primer to use? I was hoping for something that sets up quickly.
I used Zinsser Cover Stain with good result...sets up in under an hour.
I ended up using Zinsser 123. It worked pretty good, but did not lay as flat as I would have liked. I suspect you give up a little of that when you get the quick dry times.
