Need to seal a very porous, significantly eroded exterior brick facade on a beachfront house. I was going to use Thompson’s or similar, but someone recommended Lifetimeâ„¢ silicone sealer- anyone have experience with this, or any recommendations?
thanks
Bill
I use a product called Professional water sealer from PK Professional of K ansas. They make three strenghts but I have never used any but the regular. Have never had a failure or a problem with this product. Does not impart any gloss or sheen to the brick, just make sure its how you want it to look before you seal it. mask it like you mean it, once cured , this cannot be removed{especially glass]. wash out your sprayer about 3 times w/thinner if you expect to use it again. good luck, jim
