On exterior walls that will be bricked, what is the best sheathing to use on 2×4 framed walls? Thanks for your help.
Ed
Ed
Ed W - You want a really stiff wall behind the brick to prevent cracks. My preference would be for 5/8" or 3/4" exterior grade plywood, depending on the height of the brick.
By the way, depending on the height of the brick, 2 x 4's might not cut it for lateral forces on the brick wall (wind loading)to prevent cracks. We have a brick addition going up right now with a cornice height of about 14 feet and the structural engineer required 2 x 6 Timberstrand 16" o.c. and 3/4" sheathing for L/600 criteria.
Don't forget 3/4"-1" airspace, felt, ties, weepholes, mortar net - etc. lots of good masonry accessories around today.
Jeff Clarke
On exterior walls that will be bricked, what is the best sheathing to use on 2x4 framed walls? Thanks for your help.
Ed
