Our house is built on a slab and we have moisture issues in the lower level during the summer. It gets very humid down there which the mold likes. We are replacing about 400 sq ft of carpet with an engineered wood floor. Is there any killer vapor barrier we should be considering like Bostik MVP4 or should we just go with the old fashioned 6 mm plastic sheeting? I know some engineered woods floor come with a built in vapor barrier – any recommendations?
Many thnaks
TJEM
Consider that a part of the problem is simply that the floor is so much colder than the rest of the house.
http://www.stegoindustries.com/photo_gallery/a_field_of_yellow.html
this is what we use, but it is a performance vapor barrier, not your everyday plastic
Try this: tape a 24" square piece of 6-mil poly onto your slab. Wait a couple of days, and see where the condensation occurs. If it's under the poly, you need a well-sealed vapor barrier (6 mil poly should be fine).
If condensation occurs on top of the poly, Dan is correct, and you have moisture precipitating out of the air. Reducing the humidity level in the house would be wise in that case.
ok thanks - I have taped down some 4mm poly (hope that will do) and will check for moisture. During the summer we run at 60 to 70% humidity down there. From what I read on the net that may be to high to put down engineered wood even if the slab is dry?
4mm should suffice. The thinner it is the more it "breathes" which may change your results slightly but probably not by much. If you get condensation on top of the plastic, and I suspect you will, you probably shouldn't install your floor unless you install a dehumidification system of some sort.
