I’m interested in using bi-fold doors in an application where they will oftentimes be ‘folded open’ parallel to the wall to which they are hinged. I understand that there is a provision for dropping the pin that normally travels within the track in order to permit such folding. However, I would prefer having a track which permits the aforementioned folded-open-and-parallel-to-wall configuration, ie, I don’t wanna be messing w/ dropping the pin all the time. Does anyone know if such tracks are available at reasonable cost….and do they work well?
Brian
What size and how heavy are the doors? There is cabinet hardware available that allows a door to open 90degrees then travel back in a path perpendicular to the way it started. Travels on kind or a drawer slide. These are available in standard 2" increments up to (I think) 28". Just recently I looked into them to hold a bifold on each side of a big screen tv cabinet. I think they are supposed to handle 100 lbs per pair no problem.
*B, Johnson hardware (the pocket door guys) make a bi-fold kit that will do what I think your looking for. We've used them a few times and have had good luck with them. Your lumber guy should be able to order them for you, mine usually takes 3 days to get them.Sorry I don't have their book at home to give you the product number if you can't find it let me know.
*Thanks, Fred! A lot of my questions get answered if I just hang around long enough.Johnson Hardware SiteBut I am still tempted to build something from scratch using butt hinges & maybe ball catches -- these two 2-0 solid wood doors are moderately heavy. A 4" butt hinge would allow the 2-4' door to open flat across the casing. Maybe create a subtle overhead track from wood, a dowel as the pin? Maybe no track, & mortise a hand pull into one of the inside hinge stiles. Not sure...
