Does anyone have any experience with these style balisters? Its not a real challange but I wanted to see if anyone had any neat tricks. Thanks!
Fine Homebuilding Recommended Products
Fall Protection
With a 50-ft safety line and a hinged, reusable anchor, this complete safety harness kit allows you to easily protect yourself while working comfortably and efficiently.
N95 Respirator
PPE is a must, especially when cutting and sanding. We recommend you always have a box of respirator masks on the job site.
Caulking Gun
It's important for any insulator to have a good caulking gun for air sealing or adhesives, and this one features a revolving frame that makes orienting the tip a breeze.
Nitrile Work Gloves
Do yourself a favor and protect your hands while you work. These lightweight, breathable work gloves will keep your hands safe while cutting and fitting.
Get Your House Right: Architectural Elements to Use & Avoid
If you are designing or remodeling a traditional home and want to make sure that you get all the finish details right, this book is for you. Marianne’s drawings are illustrative, covering every aspect of interior and exterior finishes.
Personally, I'd drill-jig the works and use dowels....through the center stile, through the spacers, and then into both end stiles.
*Stan, Armin, Boss, comon youse guys I want 6 cents worth! ;)
*Allen: I have never done that style, but Phils way sounds good.Depending on the situation, you could make an alignment jig and pin these together, or screw and plug the unit together.If time is of no concern, you could mortise and tenon these together. This is probably the most time consuming, but I feel would be the ultimate way. Reality would dictate a less labor intensive way however.
*I guess I'll have to put some dowells in the bottom and nail them down to the treads.
*Just nail it.
*wait, ralph... don't jump until i move the vase !
*Nice job Ralph....now I'm all inspired for Mon. a.m.
*Allen, all the above would be good. Me, since I'm the master at burning up time on mindless detail I would mortice all joints and use square pegs as tenons. Dowel holes just seem to want to drift to much. Are you really going to pay me 6 cents for this? I take MC & Visa.
*Go to where Ralph's photo is. The only tool you'll need is a sawz-all. Looks like this method will get you 21 balisters.Rich Beckman
*Ralph: Nice looking balustrade!
*Thanks, Stan.Allen, let's see a pic of yours when you're done.
