Hi,
What is the general maximum allowable “bird mouth cut ‘ on a roof rafter ?
Does the roof pitch affects the depth of cuts ?
Hi,
What is the general maximum allowable "bird mouth cut ' on a roof rafter ?
8x8, there is no "maximum" allowable birdsmouth cut. You are free to cut all of it out.
No, the depth of the cut is determined by the carpenter. The depth is usually established to work with some other desired result.
In most instances, the heel will not be less than 4" but that is not a fast, fixed rule. The "heel" is referred to the "height above plate". It is measured at the outside wall line. I've worked on roofs with as much as 48" of "HAP" and as little as nothing.
blue
Just because you can, doesn't mean you should!
Warning! Be cautious when taking any framing advice from me. There are some in here who think I'm a hackmeister...they might be right! Of course, they might be wrong too!
