bizarre insulation / slab question.
alligator22 | Posted in Energy, Heating & Insulation on December 5, 2007 05:13am
Ok not sure how it came to this but I have a bizarre insulation situation emerging. Wondering (but doubting) if anyone has ever encountered something similar.
Basically we had a significant backfill issue below new basement slab-on-grade in a highly inaccessible area. Rather than cart tons of backfill in our contractor had the bright idea to have a suspended slab between old house foundation wall and new perimeter foundation, held on steel angles on top of which is welded a steel bed for concrete. I guess that this is a type of construction in commercial buildings.
What I didn’t realize until looking at it today is that by not backfilling there will be an air pocket that will be effectively encapsulated within the slab. That is to say something like the following:
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA slab
HSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSF h is old house S is steel F is new exterior foundation
H–––––––––––––––––––––––––––––––––––––––F H is house F is new ext foundation – is air
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX is grade with R-5 or R-10 and vapor barrier.
At this point my choices are the following:
1) just hope for the best
2) Ask contractor to stuff or spray as much possible insulation material into encapsulated air gap.
3) start over / do something different – obviously most expensive.
Help?? Does this make sense? I am sure it sounds bizarre
TC
  1. bobtim | Dec 05, 2007 05:19am | #1
    I'm confused
    FYI  all crawlspaces need access and might need to be vented.
    1. alligator22 | Dec 05, 2007 05:52am | #2
      Well it is only 4" deep. Solidly encased in concrete on all sides. Is it still a crawlspace?
      1. alwaysoverbudget | Dec 06, 2007 02:29am | #8
        you mean that the lowest spot on this is only going to be 4 inches of space? make life easy fill it with concrete.larryif a man speaks in the forest,and there's not a woman to hear him,is he still wrong?
        1. bobtim | Dec 06, 2007 02:40am | #9
          Heck he could have filled the space with  high density foam panels.
  2. Danno | Dec 05, 2007 05:53am | #3
    And the air gap is bad because...?
    If the vapor barrier is directly on the ground and the air gap is above it, I don't see a problem (but I'm not a foundation or concrete expert).
    My main concern would be that the concrete is strong enough not to crack (it's supported by steel, right?).
    McDesign | Dec 05, 2007 05:57am | #4
    So, you like ASCII art, too?  Still struggling to understand your situation.
              ,d8'
                ,d88"
               ,888;
              ,888;
              8888
             :8888
             `8888
             `8888
              Y888.
             b 888;
             8.:888.
             :8.:88b
             :88."88b
              888.:88b.
               `Y8;`888
              :b `8b`888o
               88o Yb`888b
               :88b."b:8888.
                `888o"b88888b
                , "88o8d88oY88.     `Y8o.                ,8888bo
                :8o "8bY888b:88b      "888888888888b.    Y8;   Y8.
                 888o`8b8888b`888.     `Y88888888"d88ooo. "     88
                 Y888b`8888888`Y88b        88888P:"Y8888888o    88'
                  `888b`8888888."88b     d8888888888P"""'  `"  d8;
                  b.`"8bY8888888o`Y8b.  d888`888888. ooo.  ,oo88"
                  Y88o."888888888b.Y8b :8888:888888bo.`8888888888
                  o`"Y8bd88888Y8888.Y8od8Y88:88888888bo "88888`"'
                  :bo `"888888'Y8888 Y888.Y8'88888' `""" `"88'
                   "888od888888'8888;`8888.Yb'888
                  :b `"88888888b`8888 88:88o`Y888
                  :88boo.Y888888.Y888 88;8888o Y8.
                  :8888888888888;:888;88;P:'888o`8.
                  :P ,oooo"888888:888 88'8d8.`888oY.
                  `d888888888888P:88Pd8Pd8b"8b."88888oo
                 o88888888888888 d8888Pb888o"88o'"88P"88P'
                 88""' ,oo8888P`d888PYo88888b'Y88o'Y8.
                 8`oo8888888888888"',888888888o'"88bPYb
                 o88888888888888P'  d88888888888bo"Y8bPb.
                :888888"Yd88888P  ,d888888888888888oPY8db.
                8888"',88888888' ,"'  oooo888888888888.Y88
               :88P',8888888888;d88888888888888P"Y88888b:8.
                88 d888d88888888dY8888888888888888b'8888b:8
                :;d888;88888888888888888888o'"888888b`888;8;
                 ,888P:8888888888888888888888b.Y88888b'888:;
                 ,888;8888 88888888888888bd888b`888888bY88:;
                  888;8888 8888888888888888dY88.8888888`88d;
                  Y88.Y888b888888"  .`Y88888:88;:888888 888'
                  `Y8;:8888:88888   8b 88888888b8888888d888
                  ,d'8.8888.Y888888888 88888888d88888Y;888'
                  888bY Y888.88888888P,8888Pd8888888P8:88'
                 888888o Y8888d88888Yd8888Pd8888888P8`88'
                d88888888boY888888888888P`88888888Pd'88"
               :88P888;8888"Ybd88"""P""d888888888"dPdP'  -hrr-
               888b888;8888 :8888888;  888Y8888P`8PdP'
               888:888;8888;d8888888; :88':888Pb8"dP
               888:8888`888b888Po888  `8P d88Pd8PdP'
               888:8888.88888P`o888'   8; 88P88;d8'
               888;8888b8888'd8888'    `8 8888Pd8'
               :88;:8888888888888         8888:88
                Y88.888888d8888P          888;888
                 88;888888888P'           :88b888
                 `88`888888P'             `88;888;
                  Y8 88888"                Y8b888b
                   Y888888                  Y88888b
                   d888888b.                 Y88888bood8888.
                  :888b88888P88P88b           "8888888888888
                   :8d888888b888d88             Y8888888888;
  4. gstringe | Dec 05, 2007 05:59am | #5
    I too am somewhat confused. What is the physical dimensions of this air pocket? Why do you think an air pocket is a problem?
    Nobody gets in to see the wizard...not nobody...not no how!
  5. IdahoDon | Dec 05, 2007 07:03am | #6
    I'm guessing you are worried about heat loss through the exterior foundation wall under the steel?
    Have them place some ridgid foam sheets to the inside of the foundation wall before the steel is in place.  If it's really cold where you are, it wouldn't hurt to also insulate the exterior of the foundation or even use ICF's to rest your suspended slab on.
    If you want radiant heat, you'll probably have to have the engineer's ok to run the tubing in the self supporting slab.  We would ask and run the tubing if you wanted to use radiant or not, since eventually everyone wishes they would have.  It's ok to install the tubing, having it inspected and then leave it capped.
    Best of luck.
  6. alligator22 | Dec 05, 2007 08:05pm | #7
    OK let me try again. Here is a picture (not ascii....)
    Any suggestions?
    1. MartinHolladay | Dec 09, 2007 11:09pm | #11
      Alligator,
      What your pdf illustration does not show is any vertical insulation on the inside or outside of your new perimeter foundation, which you have labeled "cinder block wall" in your sketch.  The sloping "horizontal" insulation under the slab is shown with an airspace between the insulation and the slab;  this insulation will be somewhat less effective than it would have been if it had been installed directly under the slab, because concrete block masonry is not airtight (although it can be made so).  Vertical insulation on the new concrete block perimeter wall is essential.
    2. DaveRicheson | Dec 21, 2007 03:00pm | #12
      The heat loss from the air space above the insulation and vp as you have it drawn won't be that significant.
      As Martin pointed out the loss through the edge of the slab and wall will be the biggie.
      If the slab  and foundation wall are already done, the best you can do now is add exterior insulation to the foundation wall. Take it all the way down to the top of the footing (below frost line).
      Dave
  7. mike_maines | Dec 06, 2007 02:53am | #10
    If you were using prestressed or poststressed concrete panels for your slab, I wouldn't worry.
    If you had an engineer spec the rebar placement and concrete mix, I wouldn't worry.
    If your span is under 4 to 6 feet, I wouldn't worry.
    Other than that I'd worry.
