Black Mold on wall board
Don | Posted in General Discussion on January 20, 2008 06:17am
Got a problem: Daughter bought a house in Southern MS. Right after she bought it, had a sewer backup that caused a floor drain in bath to overflow & spread about 1 inch of water all over floor. Amazingly, it ran out under the sill plates into the garage & some got into an adjacent bathroom. House id 30+ yrs old. Why on earth there is a floor drain is beyond me.
Had no idea the magnitude of the damage till about a month later when daughter decided to replace filter in return air duct that ran behind shower in bath that had overflow. Opened louver & found black mold along back of wallboard forming one wall of return air duct. Also discovered that her shower head chrome nipple had corroded & been leaking down into same space, probably compounding the mold problem. This meant that return air was picking up mold spores & spreading around entire house. Simultaneously, she decided to repaint second bath on other side of return air duct and discovered that wallboard at base was crumpling & paper peeled off face. Black mold had a foothold on that wall, also. While cleaning this mess out, I wore an MSA mask w/ a P100 filter. Called the MSA folks first & they said that was adequate protection against black mold.
I have since (Like this past week) installed a real galvanized return air duct to isolate any black mold in wall space. There was about 11 feet of duct that was nothing more than 2X4’s & wallboard. Have removed all the moldy wallboard from several areas, having to go about 2 feet up wall to get to sound wallboard, so am going up 4 feet to replace – figured that it is no more work to go 4 feet than to go 2 feet.
Now to the question – I can see the back side of the bathroom wallboard at the sillplate – which is on a slab. The bath has 4 inch tile along the base of the wallboard that has the black mold growing on it inside the wall cvity. As soon as I get the current areas closed in, I will remove the tile & its walllboard. Is there any reason why, when replacing this mess, I cannot put a 3 1/2 inch band of 1/2 inch Hardiebacker along the sillplates to adhere the replacement tile to then continue up with the new Densearmor anti-mold wallboard to a horizontwal joint w/ the current wallboard? I figure that the HB would not wick water up into the new WB & the band of Dense3armor would protect against moisture & mold in the lower spaces of the wall.
Don
Don Reinhard
The Glass Masterworks
“If it scratches, I etch it!”
  1. DanH | Jan 20, 2008 06:26pm | #1
    I'm pretty sure that the HardiBacker will wick water too -- don't see the point in switchiing materials for that narrow of a band.  If you do go with a band like that, separate it from the board above with a thin layer of caulk.  But the best defense is to simply keep anything porous about 1/4" above the floor.
    The damage you're describing, of course, is probably not due to the overflow but rather to decades of splashed/leaked water and humidity in the baths.  Definitely use moisture/mold resistant materials everywhere nearby.
    Edited 1/20/2008 5:51 pm by DanH
  2. Don | Jan 20, 2008 11:02pm | #2
    Bump, bump, bump
    Don Reinhard
    "If it scratches, I etch it!"
Wiring for Subpanels: The Right Cables
When running cable to a subpanel for a home addition, pay attention to the size of the wire and the amperage of the breaker.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
