bladder tank or variable speed const….
justinbearing | Posted in General Discussion on December 17, 2005 03:15am
standard pump and 40 gallon pressure tank or the new variable speed constant pressure “jet pumps.”
A couple bids for our well came in with these “jet pumps” and a couple with a pump and “bladder” pressure tank.
Seems to me that the jet pumps would use more electricity even being 2 phase.
Thanks for any input you’ve got.
    BillHartmann | Dec 17, 2005 04:17am | #1
    Are you sure that the variable speed is Jet Pump?
    All of them that I have heard about for wells are submersables.
    http://www.do-it-yourself-pumps.com/constant-pressure.htm
    http://www.franklin-electric.com/CatalogSubmersible/ConstantPressureControllers.aspx
    http://www.bluewaterpumps.com/catalog/item/1014375/556942.htm
    http://www.sampleswelldrilling.com/pumps.htm
    Now surface mounte vairable speed pumps are used for pressure boosting and distribution systems.
    1. justinbearing | Dec 17, 2005 07:08am | #2
      thanks.Due to the low flow of the wells in the area (.25 g/m on our shared) holding tanks are needed. So the submersible pumps to the tank and the something for the tank to the house.http://tinyurl.com/cdsea
