Blocking between rafters and joists?
blownonfuel | Posted in Construction Techniques on November 6, 2008 05:42am
I have seen some framers use blocking between rafters and joists. Should the blocking be placed in certain locations in the joists or rafters? Is it better for sheathing on the roof?
  1. RedfordHenry | Nov 06, 2008 06:36am | #1
    I've blocked joists, but never rafters (this would block airflow from the soffit to the ridge).  Usually put joist blocking in at midspan.
    1. blownonfuel | Nov 06, 2008 06:56pm | #3
      Thanks RH.
  2. Piffin | Nov 06, 2008 02:40pm | #2
    In high wind coastal areas, you now have use blocking at ply joints or use T&G sheathing. Other than that, I have never heard of or seen blocking at either.
    1. blownonfuel | Nov 06, 2008 06:57pm | #4
      Maybe thats what i'm seeing Piffin.
