Hello all,
I’m planning on using CemPlank fiber cement siding on a new home. The lower portion of the house will have the siding oriented horizontally. There will then be what I would call a “belt” line above the windows done in wide trim and a trim color. Above that will be vertical board and batten painted the same color as the bottom.
My question is has anyone used fiber cement siding to do a vertical board and batten installation? Are there any problems or important considerations?
Thanks for any suggestions, especially useful ones ………
-Fred
Hello all,
I'm planning on using CemPlank fiber cement siding on a new home. The lower portion of the house will have the siding oriented horizontally. There will then be what I would call a "belt" line above the windows done in wide trim and a trim color. Above that will be vertical board and batten painted the same color as the bottom.
Thanks for any suggestions, especially useful ones.........
-Fred
