Board & batten siding, alignment w/ trim
davidmeiland | Posted in Construction Techniques on June 27, 2006 06:18am
Need yer opinion on this:
Tomorrow we start putting board and batten siding on the shop. It’s 1×10 plus 1×3, vertically of course, and it nets 1-3/8″ thick wherever a batten sits on a board. The windows and doors are trimmed with 2×4, net 1-9/16″ thick.
So, of course there are places where a batten will land on the corner of a window or door. This means that part of the batten would stop and the rest would continue until it gets below the trim… a big notch in the batten as it were. I’ve seen plenty of jobs done like that and think it looks heinous.
There are 22 windows and 3 doors and they are where they are. No amount of forethought could have prevented every single such ‘collision’.
My thought is to rip the occasional 1×10 strategically, narrowing down a piece or two so as to alter the placement of the potentially offending battens. It would have to be done carefully so as to appear random. I think this will look better than a perfectly spaced siding install where the battens occasionally klutz the window trim.
The siding is from a small mill, and there are already some variations in thickness and width, so we’re already gonna look somewhat random. The shop replaces a very old barn so we’re not trying for perfect.
Whatcha think?
  1. jesse | Jun 27, 2006 07:52am | #1
    I have cheated battens a lot to avoid this, and sometimes horrified myself by how much it takes...but when all is said and done, you could never tell. I think with the random look you will be fine.
    CapnMac | Jun 27, 2006 08:05am | #2
    Well, what I've doone is to work from what is there, in a horizontal "story pole" sort of way.  Which is logical, just turned 90 degrees.
    So, start from the windows, and work out to where the corner boards will "close" the walls.  Not a bad idea to do some layout between windows & doors, if only to get some sort of order & discipline to the trim.  It takes some finesseing, but it works out much nicer than a 1" wide ripped down batten on one window side, then a 3" wide gap to the next batten, and then some other spacing at the next window.
    But, that's me, too.  Others differ.
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
