Boogerin’ on the tables continued….
| Posted in Construction Techniques on January 27, 2005 03:28am
I couldn’t find that last thread that I was workin on so I just added a new one here. I’m supposed to be finishing up the truss table building…but I have a few combo walls to do.
The first pic shows the completed wall being sent to its place. The next ones will show how it’s done. The mono gable wall is attached to the sidewall. I framed the side wall first, then sheathed it, then framed the attached mono gable.
Quite often, they send out mono gables to attach to the wall…sometimes we use them, some times we dont. This time, I didn’t have a choice…they didn’t send any because that section is all handframed.
blue
Just because you can, doesn’t mean you should!
Warning! Be cautious when taking any framing advice from me. There are some in here who think I’m a hackmeister…they might be right! Of course, they might be wrong too!
  1. blue_eyed_devil | Jan 27, 2005 03:34am | #1
    I just found another pic of that wall. This shows the wall before I installed the hardie. I first install all the trim. This gives me a framework to fill with siding.
    blue
    Just because you can, doesn't mean you should!
    Warning! Be cautious when taking any framing advice from me. There are some in here who think I'm a hackmeister...they might be right! Of course, they might be wrong too!
    1. blue_eyed_devil | Jan 27, 2005 03:40am | #2
      That last wall was the farthest wall from the crane. We had a tough time setting it because we couldn't reach all the way without going past the tipping range.
      The next section is the bedroom in the back of the house. I've already finished the back wall and it's laying on the table. Heres a few pics of the sidewall in progress.
      blueJust because you can, doesn't mean you should!
      1. blue_eyed_devil | Jan 27, 2005 03:44am | #3
        These two pics show the method that I use to determine the length of the soffit, where it lays over a roof. By cutting everything exactly to the theoretical length and angle, it should fit properly. I've cut the siding to be exactly 1" above the roof deck. The frieze, soffit and fascia will automatically be 1" too.
        blue
        1. blue_eyed_devil | Jan 27, 2005 03:50am | #4
          I almost always run the subfascia's long, then accurately mark them and cut them to the proper length. It's just a lot faster to do it that way then to cut the parts first, then wrestle them into their exact spot.
          I mark the 12/12 angle and cut this to length before I run the fascia.
          1. blue_eyed_devil | Jan 27, 2005 03:51am | #5
            I use the same technique for the fascia.
          2. blue_eyed_devil | Jan 27, 2005 03:54am | #6
            The side wall is done. I'll send it up, then immediately send up the back wall. I have to make room for the other side wall which is almost 28 feet long.
          3. blue_eyed_devil | Jan 27, 2005 03:57am | #8
            Heres the next two walls being sent.
            I've got the corner boards tacked onto the window of the back wall. Ben will nail them on when he's sheathing the roof.
          4. blue_eyed_devil | Jan 27, 2005 04:05am | #10
            Here's Ben tieing the tops together. He aligns and nails all the pine first, then ties the top plates.
            The first pic shows ben and steve receiving and setting the walls. They are shown receiving the back wall here.
          5. blue_eyed_devil | Jan 27, 2005 04:15am | #11
            I framed the hipset on the table. I use two adjacent sides of the table to square up the hip set and I'm able to cut in the hip rafter and attach all the jacks too. I would have had a picture of this contraption sitting on the table, but the battery fizzled in thee cold (I left it exposed too long). Luckily, I had brought the charger and I'll be able to send in some more pics today.
            The second picture shows us standing up the front wall. I'll give you a better shot in a second. But...you can see the hipset  that I just sent in the background. We've dropped a small bunk of ply on top of the partitions.(that was actually a lot for the old boom) and ben will start sheathing that rear upper roof. We'll comfortably be able to sheath the back section by building ply racks at strategic locations. We normally use the Sky trak but we don't have any access back there.
          6. blue_eyed_devil | Jan 27, 2005 04:18am | #12
            This pic shows the front wall. Some of the wall will be behind the garage roof. Ben has already installed the saddle on the garage roof and the Hardie siding has been carefully installed to land 1'' above the saddle.
          7. blue_eyed_devil | Jan 27, 2005 04:23am | #13
            These two pics show ben and steve receiving the wall. The fit was snug and it needed a little, very little persuatsion. The 16# sledge did the trick, but I didn't get a final picture.
          8. blue_eyed_devil | Jan 27, 2005 04:26am | #14
            The final pic of the day shows Ben's progress on the hip sheathing. He's finished the rear and some of the side and he's built a plywood rack to receive the remainder of the upper load of sheathing.
            To be continued......
          9. User avater
            Timuhler | Jan 27, 2005 05:48am | #16
            Nice work Blue.  I really do appreciate you posting those pics.  Its good to see some framing pics, and it's cool to see new methods in evolution.
            Here is a pic of a rake wall we built last week.  We lifted it in with the forklift.  I forget the LB rating on the strap.   We ordered it through our lumberyard and it sure makes things easy.  We used to use a chain, but the strap is much better.
            http://pic9.picturetrail.com/VOL293/2163851/6440753/82833737.jpg
            http://pic9.picturetrail.com/VOL293/2163851/6440753/82834099.jpg
            http://pic9.picturetrail.com/VOL293/2163851/6440753/82834090.jpg
          10. blue_eyed_devil | Jan 28, 2005 05:28pm | #22
            Tim, nice pics...that's a nice wall...it's much easier to frame and sheath it on the deck!
            I've built many like that, but I do one thing different. I run the studs all the way to the top and save that 2x12 for the drywall backer! You really don't need that 2x10 there.....I don't put anything, but occasionally I'll put a 2x6 on the flat, just like a top plate.
          11. User avater
            Timuhler | Jan 28, 2005 05:48pm | #27
            Blue,
            Thanks for the comments.  I use the rafters (2x10) in this case because often I've already cut them for that section of roof.  It also saves a few steps in calculating anything else.  If I calculate one rafter and then use those to determine the height of the ridge, I've saved a step and then I can lay it on the ground, trace it and then run my studs and I don't have to use my tape measure.
            It's always evolving though.  I'm sure we'll change it again the next time.
            Stay warm
          12. arrowshooter | Jan 30, 2005 03:33am | #35
            I like the way you post the pictures.
            How do you do it?
          13. blue_eyed_devil | Jan 30, 2005 03:35am | #37
            This two ply girder will carry the rest of the trusses. It will have a two ply hipset hanging from it. You can see the larger hanger ready for it.
          14. blue_eyed_devil | Jan 30, 2005 03:38am | #38
            Before I send it, I measure the overall height of the girder. I can use this number to cut the entire conventional rafter package and send it up in parts, or build the entire thing on the ground.
            We'll send it up in parts.
          15. blue_eyed_devil | Jan 30, 2005 03:40am | #39
            I snub the tip of the girder. This snubbing give it a flat 1.5" surface on the tip. This is any old technique that I use if I measure the length of the ridge "in place". I'll snap a picture on Monday to explain why I like that snub.
          16. blue_eyed_devil | Jan 30, 2005 03:43am | #40
            We set all the "regular" trusses and that leaves us with the hipset. We use the table to build the hipset. It offers a convenient place to stand while we cut and install the hips and jacks.
          17. blue_eyed_devil | Jan 30, 2005 03:45am | #41
            Before we can set the hipset, we have to put the final wall up. We set the hipset aside and prepare the finality.
          18. blue_eyed_devil | Jan 30, 2005 03:47am | #42
            The tale's work is now done and we cut out the windows and paper and overhang our friend.
          19. blue_eyed_devil | Jan 30, 2005 03:51am | #43
            We set the wall and Ben and Frank are tieing the pine together. Their corner fit perfect. My corner is 4" long...I added a wall's thickness when I shouldnt' have. I'll have to cut it back off a ladder...a ten minute fix.
            The hipset is hoisted...I would have taken some shots of it getting set, but I was one of the setters!
          20. blue_eyed_devil | Jan 30, 2005 03:55am | #44
            The hipset fit well and the master suite is now ready to cover. The front corner patch still needs to be completed. I was only able to get the frieze finished before the hipset was on it's way, so the rest of that repair will have to wait till monday.
            That about sums up the truss boogerin' on the tables. I'll be posting some hip return pix from this house tomorrow but I'll post them in a differnt thread.
          21. blue_eyed_devil | Jan 30, 2005 03:56am | #45
            One more thing....I'll be happy to post larger versions of any of these pics upon request. I also have a bunch more shots that I didn't show. If there's something in particular of interest, just give a shout.
          22. Snort | Jan 30, 2005 04:18am | #46
            Jeeze, educational and entertaining, I'm about to gag<G> Don't worry, we can fix that later!
          23. blue_eyed_devil | Jan 30, 2005 05:36pm | #49
            Yer funny BB.
            Hey, did you ever get all the rodent feed out of that vintage PC? Did you get the retaining nut off?
          24. User avater
            Gunner | Jan 30, 2005 06:06am | #47
            You got any girl helper pics????????
            Actualy I have enjoyed the heck out of your building threads latley. You and Tim Uhler are keeping me very interesed.Who Dares Wins.
          25. blue_eyed_devil | Jan 30, 2005 05:40pm | #50
            Thanks Gunner. I've always been a construction voyeur too. Even today, I can watch with interest, guys standing things up. I'm alway curious about their methods, motivations and often are impressed with their resolve, even if I don't agree with the technique in it's entirity.
          26. User avater
            Timuhler | Jan 30, 2005 07:00pm | #51
            I upload the pics to http://www.picturetrail.com/ and then I can copy the url and post it here.  It pretty simple.
          27. blue_eyed_devil | Jan 30, 2005 10:58pm | #52
            Tim, whats the advantage to using picture trail?
          28. User avater
            Timuhler | Jan 30, 2005 11:42pm | #53
            Blue,
            The advantage to me is that the pics open in a new window and once I've uploaded them onto picturetrail, I can go get the url and post anywhere.  The biggest advantage, is that some forums don't allows pics bigger than a certain size.  I can get around that by posting a link.
          29. blue_eyed_devil | Jan 31, 2005 04:44pm | #54
            Tim, is there a charge to use picturetrail?
          30. User avater
            Timuhler | Jan 31, 2005 05:30pm | #55
            Blue,
            I think I was using it for free, but then I went ahead and bought an account.  I don't recall the upgraded features, but it's been worth it.
          31. butch | Jan 27, 2005 12:39pm | #19
            http://forums.taunton.com/n/mb/at.asp?webtag=tp-breaktime&guid=C04069A0-B450-4505-9B47-F7AB94CD7B87&frames=no
            The way the strap for the crane
             is shown on this picture
            Doesn't it pull up on your overhang?
          32. jimblodgett | Jan 27, 2005 12:58pm | #20
            What the heck is all that white fluffy stuff, blue?
          33. blue_eyed_devil | Jan 28, 2005 05:34pm | #26
            Dandruff.
          34. blue_eyed_devil | Jan 28, 2005 05:33pm | #25
            Very astute observation butch!
            That strap would indeed collapse the overhang but I took a calculated risk. I have collapsed a few in my days and I'm keenly aware of the risks. If you look closely, you will see three braces nailed on the top. The middle brace is placed next to the strap and it is a solidly nailed 2x4. It held. If the wall was much heavier, I would have hooked it differently.
          35. butch | Jan 30, 2005 01:36pm | #48
            You see we are paying attention!!
            and what gunner said
          36. Shep | Jan 27, 2005 05:06am | #15
            You tryin' to drum up some interest in yer work?
            Its a shame all that nice framing has to eventually be covered up.
            You do nice work- I just wish we lived closer.
            Where are you in Mi? I've got a SIL in St. Johns, and a nephew in Lansing, as well as more out by GR and Holland.
          37. blue_eyed_devil | Jan 28, 2005 05:25pm | #21
            Thanks Shep.
            I'm sw of Flint...about 45min from Lansing. I have a cousin in GR. I can't remember where St John's is.
          38. Framer | Jan 28, 2005 08:43pm | #28
            Blue,I can't remember what thread it was in but I told you I was going to count how many nails there were in each coil for my Hitachi Coil nailer for you.8 penny 250 nails per coil with 12 coils @ 3000 per box10 penny 208 nails per coil with 12 coils @ 2500 per box.Sorry it took so long maybe because my brain is frozen.........;-)Joe Carola
          39. blue_eyed_devil | Jan 30, 2005 03:00am | #29
            Thanks Joe. I was just trying to figure out if the coils were that much more efficient.
            The stick nails I use are clipped head, .131, 12d and they contain 37 nails per stick. I can load two sticks in the magazine. Since I don't like to carry much weight in my tool belt, I normally put two reload sticks in my special nail pouch. That means that I'm armed with (4x37) 148 nails. Most of the guys carry 4-6  clips and I used to do that too, and will carry that many if I'm clamoring up onto the trusses or something.
            I figure it takes me about ten seconds to load two clips. I'll time it on Monday but ten seconds seems like a good average amount.
            I'm not convinced that its significantly faster to use the coils. It sounds like it's a wash, but I could see where coil guys would "feel" like it's faster.
          40. blue_eyed_devil | Jan 30, 2005 03:23am | #30
            Well, I've come to the end of the truss/table boogerin for this house.
            This pic shows the largest gable that will mate with it's smaller twin gable that spans over the foyer/entrance.
            Notice that we've installed a temp roof to fit the overhangs to.
          41. blue_eyed_devil | Jan 30, 2005 03:25am | #31
            This is the smaller of the two gables and sits in front of the larger one.
          42. blue_eyed_devil | Jan 30, 2005 03:27am | #32
            Frank is removing the temp roof and this pair of gables is ready to send. We thought about stacking them as one unit and finishing all the pine and small section of roof sheating (there is about a 12'' offset), but decided not to because we will send someone up on the lift to do some crown and paper repair work anyways.
          43. blue_eyed_devil | Jan 30, 2005 03:29am | #33
            Ben is up there receiving that small gable.
          44. blue_eyed_devil | Jan 30, 2005 03:31am | #34
            Heres a frontal shot of the twin gables in their finished spot. I've got some pics of the hip return boxes getting assembled..I'll post that tomorrow morning...I'm hurrying right now to watch the Pistons tonite.
          45. blue_eyed_devil | Jan 30, 2005 03:33am | #36
            We're all down hill now. We have to get a girder set to carry the master suite trusses.
        skyecore | Jan 27, 2005 03:55am | #7
        wow that looks cold! thanks for the pics blue.______________________________________________
        --> measure once / scribble several lines / spend some time figuring out wich scribble / cut the wrong line / get mad
        1. blue_eyed_devil | Jan 27, 2005 04:02am | #9
          Skye, it's my pleasure!
          Yu must be living in a warm climate...I'm jealous.
          Actually, it started out about 27 degrees today, with a little wind. It got steadily colder...down to about 20 and always a slight breeze. I'm not complaining....it could be a lot, lot worse. Besides, I keep a nice warm fire nearby and I'm not afraid to keep it company. Because of the wind, I did keep my overcoat on, which is a short windbreaker that is used for duckhunting. It rides above my tool belt and it's perfect when it's windy or snowy or rainy.
          blue
  2. JohnT8 | Jan 27, 2005 07:21am | #17
    goood lord, blue, where the HECK to do live that you've got snow on the ground in May?!
    The two most abundant things in the universe are hydrogen and stupidity. -- Harlan Ellison
    1. professor | Jan 27, 2005 07:34am | #18
      John,
      those pics were taken today..... just Blue is a better framer than camera operator...... as he has said before he still hasn't figured out how to put the correct date into his camera.       This is a really cool thread.  I always enjoy his pics.
      He is in the Detroit area of MI
      1. blue_eyed_devil | Jan 28, 2005 05:30pm | #24
        Your right Prof! I did reset the camera today...I just don't have time to post any pics.
    2. blue_eyed_devil | Jan 28, 2005 05:29pm | #23
      Lol John. We almost ALWAYS get a snow storm in may around here. In fact, it's usually a fairly hefty dumping.
  • A Closer Look at Smart Water Leak Detection Systems
