Just got a Bosch table saw and I want to make a zero-clearance insert for it. The insert itself is a little thinner than the usual blanks that are sold. I could make one but this is the saw that has the riving knife so I want to stick with the factory types. Has anyone ever filled the cavity with Bondo and raised the blade through that? If so how did that work?
Thanks.
Most nights are crystal clear, but tonight it’s like he’s stuck between stations.
use a piece of 1/2" lexan and make a whole new one..
WOW!!! What a Ride!
I'm lazy. I have Bondo; I don't have lexan. :-)
Most nights are crystal clear, but tonight it's like he's stuck between stations.
Edited 11/19/2007 12:06 pm ET by JJV
cheap too....
so let us know how the Bondo works out...
I prefer the term "thrifty". ha ha....
A google search shows me that my idea is not original nor far-fetched. We'll see how it goes.
thrifty it is...
without re-inforcing, I think the bondo would flake right away or chip off.
Here is how I would try this -
take a piece of glass at least as big as the insert.
spray it down with wax. or paste wax it.
lay the Bosch insert upside down of the glass plate. Maybe sand the smooth spots to give mechanical bondability first
Mix up some clear epoxy along with a bit of ceramic filler beads
Pour that in the slot.
Let it cure.
If need be, sand the finish top smooth again.
Run the spinning blade up through to get the zero clearance slot
Didn't think of epoxy. Worth investigating. Don't know if I have enough in the shop though. I try to not keep too much of it around lest it go bad.
Use phenolic microballoons, not ceramic or silica filler powder - much, much easier on the blade as it's raised through the insert. Something like West System 407 or 410 would be great. The silica filler cures rock-hard.
did
<!---->Cure Diabetes - Whitefish, Montana, 2007!<!---->
<!---->Donate Online!<!---->
How much thinner is the insert? I make my own zero clearance inserts for my Craftsman TS using 1/4" plywood. Since it isn't really 1/4" thick, the insert is slightly below the saw table until I build it up with 3-4 layers of good old duct tape.
I've been doing this for 4-5 years and it works great. I have inserts for several blades, dado cutters, and even one blade insert with a 45* slot thru it. A couple of my old inserts were getting pretty ratty, so a couple of weeks ago, I made a new batch. I'm good for another 4-5 years. - lol
