Has anyone used or installed the relatively new foot-kit adaptor for the Bostitch M111 cleat nailer??
This is the one made for installing prefinished hardwood flooring.
I have a 2005 model and wonder if this kit will fit and is worth the money ($80)
Bostitch tech help doesn’t open until Monday am.
I have the Flooring Stapler and it came with the kit. It works excellent, and is definately worth the money if it's not included. Just keep it clean though or it will scratch as you roll it along.
I posted the original question so long ago that I forgot about it!!
You must be the only guy out there with one of these foot kits on his nailer!!
Does this bear against the tongue of the flooring or does it bear against the side of the flooring itself??
In the picture I saw, it looked like it sat against the tongue, which would be a big benefit in not nicking up the side of a piece of prefinished flooring.
it's a wide base with two wheels in it that roll along the surface of the sub floor behind the actual flooring. the shoe of the stapler/nailer protrudes throught the base and rests onto the tongue of the flooring just like it normally would without the base. Thats the only part that actually touches the flooring unless it tips forward. The benifit of it is that you can just roll the nailer along without lifting and moving it for every nail.
I got it...Thanks
