Breaker box full/how to add a separat…
| Posted in General Discussion on November 4, 2000 04:19am
A friend of mine needs some help wiring a hot tub. It is outdoors and requires a 4 wire 240v 50amp setup. His panel is completely full, so I told him I’d check on how to add a box to get him set up.
Can you tell me what he needs to do? It’s about a 35 foot run to the tub from the panel. He’s got about a 15 year old square d panel, everything looks pretty good there.
Thanks,
MD
  1. Mad_Dog | Nov 04, 2000 04:19am | #1
    A friend of mine needs some help wiring a hot tub. It is outdoors and requires a 4 wire 240v 50amp setup. His panel is completely full, so I told him I'd check on how to add a box to get him set up.
    Can you tell me what he needs to do? It's about a 35 foot run to the tub from the panel. He's got about a 15 year old square d panel, everything looks pretty good there.
    Thanks,
    MD
Fast, Accurate Wall Framing
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
  • Insulation Scrap Dispenser
