I’ve laid a brick “paver” floor in bed of sand with sand between the bricks. Any suggestions out there on what kind of sealer to use that will also set the sand and keep the dust down.As the room is a sun room/bathhouse that gets a fair amount of water on the floor I need a sealer that won’t discolor from the wet.
Blaine
I've laid a brick "paver" floor in bed of sand with sand between the bricks. Any suggestions out there on what kind of sealer to use that will also set the sand and keep the dust down.As the room is a sun room/bathhouse that gets a fair amount of water on the floor I need a sealer that won't discolor from the wet.
Blaine
