Need to find out the best method and details for brick flooring on a plywood and floor truss floor system. How do you handle any movement or flexure without cracking the mortar joints and setting bed?
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
How to Install Cable Rail Around Wood-Post CornersRelated Stories
Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
Podcast 551: Members-only Aftershow—Badly-Built Homes
Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
The first that comes to my mind is to make sure the trusses are designed for the extra dead load, and the spans aren't "maxed out". Otherwise you're probably going to have problems no matter what.
