I am turning an 87 year old commercial building into a private residence and I need to clean up the exterior facade. There is everything from tar left from flashing that was on an attached building we pulled down to plaster that was on the interior of the same building. I have thought about sandblasting but the problem wall is over 3,000 sq. ft. and I thought it would be very costly. Any ideas?
Here are a couple pics. I haven't been on breaktime in a very long time so I hope I have posted them correctly!
LOL -- sounds like my old 'Hood. P-Burgh's North Side. Folks there always just left it and hoped someone would build again next door to cover it up. ;-) Heck, there was one building where they even left a sink attached to the wall two stories up.
Short answer is that there is no good/cheap/easy way to do this. Heck, even "expensive" ways, like blasting, can end up compromising the brick and mortar. Worse, some of these buildings had soft brick on the inside faces (now your outside face) that are not meant to be exposed to the elements and degrade with time, so you should check for that.
The cheapest good solution may not be so cheap -- replacing the brick veneer. I've seen restorations where whole facades were removed and rebuilt, or where the veneer was stripped, turned around, and re-applied with the clean side out. Short of that, strip what you can and paint over the whole side.
Mike Hennessy
Pittsburgh, PA
Everything fits, until you put glue on it.
Do not sandblast.
Peelaway for the paint and other tough coatings, restoration cleaner for the dirt and grime, and a pressure washer. Some tuck pointing and brick replacement will be necessary.
http://www.quittintime.com/ View Image
Thanks, Do you know of a good peel away product I could find in S. C.?
http://www.peelaway.com/http://www.quittintime.com/ View Image
Excellent, thanks! I'll post the outcome.
O K not so sure that this is going to work. I may have to try another type of peel away! Wadda Ya Think?
Also check over at Old House Journal - folks there have a lot of experience with this issue.
"Ask not what the world needs. Ask what makes you come alive... then go do it. Because what the world needs is people who have come alive."
Howard Thurmanhttp://rjw-progressive.blogspot.com/
Will do, thanks!
Google "Dry Ice blasting" If there is an operater in your location, thats the ticket.
No, ZERO, NONE,NADA...abrasion or chems. it is awesome.Spheramid Enterprises Architectural Woodworks
Another alternative you may try is a product called "RemoveAll". It comes from the aircraft industry and use a process to break the bonds of the paint from the surface. It can be sprayed on and cleaned up with water. Give these guys a call and see what they say.http://www.dtep.com/removall310pl.htmI have not used any of the architectural exterior products but have used one of the interior products for some wood stripping.Diane
Thanks I'll call em!
