Broken screen door window
| Posted in General Discussion on December 5, 2002 09:24am
I have a screen door that has two windows that slide up and down.  The bottom window broke and had to be repaired.  In the meantime the top window slid down into the bottom of the screen door, and the spring loaded clip, that you use for raising and lowering the glass broke off.  The pin that locked the glass into place has broken off and is inside the window, locking the glass in place.  There is no slot that the pin can be pryed out.
Does ayone have any suggestions as how to get the glass out.
Thanks Jim,  Residentially challenged homeowner
    Qtrmeg | Dec 05, 2002 11:23pm | #1
    Take the door apart. Think screwgun.
    The glass place should have all the parts you need to put it back together.
