Building a sauna
GordonVN | Posted in Construction Techniques on October 7, 2004 03:05am
I would like suggestions for a basement sauna.The room is framed and plan to use Cedar t&g. What should go behind the cedar? I want to keep the heat in,and also stop the heat affecting the floorboards above.It will be a dry sana so I don’t know if moisture will be a problem .
Thanks for your advice . I get the idea that sheet rock is not needed but one should put insulation, then moisture barrier. then furring strips, then cedar.The living area is above the sauna and when built there would be dead space between the sauna and the floor joists.I am concerned about heat build up there from leaking hot air and radiation.
Iam reposting my original posting with a follow up as the first set of replys moved off the question.
Thanks Gordon
    artacoma | Oct 07, 2004 03:19am | #1
    I built an outdoor sauna a couple of years ago . What ya have to do is look for a book called "The Art of Sauna Building" by Bert Olavi Jalasjaa. It's got everything ya need to know about heaters, framing , layout ' ventilation etc.
    What is recomended is a foilfaced barrier behind the cedar.
    Good luck ...............Rik............
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
