I would appreciate any suggestions on the framing of Greek return cornices similar to the one in the current issue. the one we are building has the soffit returning on the gable end as well as the fascia and frieze. we are also using a 2x sub-fascia. it seems that the line of the crown molding on the return section will be lower than the front section. the return section has a flat top instead of an angle back to the gable wall
I would like any suggestions on framing Greek return cornices similar to the one in the current issue. however the one we are building has the soffit returning on the gable end as well as the fascia and frieze. we are using a 2x sub-fascia. it seems that the line of the crown molding will be lower on the return section than on the front section. the return portion has a flat top instead of an angle pitched back to the gable wall.
There was a pretty detailed article on this maybe 5 or so years back in JLC. Also, I think Bob Syvanen describes it in his book on "building a House" or something like that from Taunton.
