Have a old Bull Dog 30 amp 2 socket fuse box that needs the insulator replaced in the base under the off center screw. Seems as if the material is leather or something different maybe. Just wondering if anybody has any experience with this fuse box.
Thanks,
Why not just replace it??
If you really like the box for some reason, I'd replace it with pvc or polycarbonate or teflon.
Thanks for the information
Likely the material is some sort of phenolic composite (paper with an epoxy-like resin in it). Any sort of plastic material would work to replaced it. If you need something flexible buy a plastic or silicone piecrust rolling sheet and cut it up.
