I’ve just about max’d out my garage space along the walls with my family’s stuff. I can either hold a garage sale or build more storage space. Building would be good because it would give me an excuse to buy some more tools to do this project. I was wondering can you build cabinetry to hang from the horizontal garage supports? And what kind of joinery do you use. There is a huge cross beam of 4″ x 18″ x 20′ that spans the entire garage. More than likely, the cabinets will be against and attached to it as well as the horizontal supports. Is this doable? Or should I try something else. Thanks in advance.
russ
I've just about max'd out my garage space along the walls with my family's stuff. I can either hold a garage sale or build more storage space. Building would be good because it would give me an excuse to buy some more tools to do this project. I was wondering can you build cabinetry to hang from the horizontal garage supports? And what kind of joinery do you use. There is a huge cross beam of 4" x 18" x 20' that spans the entire garage. More than likely, the cabinets will be against and attached to it as well as the horizontal supports. Is this doable? Or should I try something else. Thanks in advance.
russ
