Calling all Breaktimers…
SYSOP | Posted in General Discussion on January 3, 2005 07:17am
As many of you know Fine Homebuilding is co-sponsoring Builders Trade ’05 show in Worcester Mass on Feb 3rd and 4th. In the booth this year we will have a “slide show” that will be running during the entire 2 day show that we hope to use to show case the work of you folks here on Breaktime. So if you have a project that you would like to have the world see, then send us your digital images.
Some things to keep in mind: All images should be as hi a resolution as possible. Here are some guidelines to follow: If sending at 72 DPI then the image should be at least 1500 X 1800 if your sending 300 DPI then make the image(s) at least 600X900. The highest resolution that your camera provides will work fine, think the bigger the better if you want, as this will be running on a 62″ TV (that we will be raffling off by the way). Be sure to compress them so that they transport through email correctly. Send as many images as you want we want this slide show to run for long time.
All submissions should be sent to [email protected], be sure to use “Builders Trade ’05 images” in the subject line.
Deadline for submissions is January 24th.  As Dan pointed out in the other thread please dont send a ton of images from the same project but Do send a ton of images from as many projects as you want.
Thanks and we’ll see you at the show: http://www.builderstrade.com/
Questions on resolution, compression or anything related to this please don’t hesitate to ask.
-Mark
SYSOP
[email protected]
  1. FHB Editor
    JFink | Jan 03, 2005 08:21pm | #1
    ...Also make sure that the size of each email is less than 5 megs, otherwise our server will bounce it back to you. You can get around this problem by sending multiple emails though.
    Justin Fink
    FHB Editorial
    1. JohnT8 | Jan 03, 2005 08:46pm | #2
      My 3 megapixel camera on high resolution takes a 2.8 megabyte picture.  With a 5meg email cap, that would be ONE picture per email.  You get some of these folks with 2-50 pics in a series detailing a project and they're gonna be there all day trying to send them (cuz 1 picture isn't enough on many of those outstanding projects).  And 3 mp is a fairly small picture size nowadays.
      You might want to holler at your IT guys and have them raise that limit.  Either that, or come up with a webpage they can upload them to (doesn't BT limit to 2 meg?)
      Edited 1/3/2005 12:51 pm ET by JohnT8
        SYSOP | Jan 03, 2005 09:33pm | #4
        JohnT8,
        Having been around graphics and graphic files since before the internet was a household word, I take it for granted that everyone knows what compression is and how it works. So yes at 2.8 megs our email system would only be able to handle 1 image per email thats where compression comes in.
        I can take a 3 meg file and "compress" it down to190k (1 meg = 1000k) so that when it is opened on the receiving end the quality of the image has suffered little if any. There are many programs out there that will allow a user to compress a file and in fact most (if not all)images come off of the camera in a compressed mode. When you click on them to open you are uncompressing them.
        For instance jpg is a compressed file format. Its just that the amount of compression varies depending on the settings one uses when saving the file or the settings that are within a camera. (When saving for our use then the highest possible quality setting is what we want but should still yield a relativly small file). So if you are able to take the image directly from the camera and enter it into your email you will see that the attached file is much smaller than the 2.8 megs that it is when opened.
        I hope this answers some of the questions but please if not ask. We really want this slide show to showcase the incredible talents that you folks have! So send us your best. -M
        SYSOP[email protected]
        Edited 1/3/2005 1:37 pm ET by SYSOP
          SamT | Jan 03, 2005 11:22pm | #7
          That can be done with an uncompressed file format such as a BMP or EXE, and on uncompressing or unzipping, you will have no loss or distortion. You won't get the kind of compression you are talking about with a BMP however. I just test zipped a 14MB BMP with Winzip and got it down to 12MB. BTW, it was a 1.8MB JPG I saved as a BMP. Both BMP and JPG are 2592px x 1952px x 16M colors
          And cannot be compressed further with out lowering quality. I Winzipped a JPG straight from the camera and only got 2% compression.
          Resizing that picture to 800x600 x 300dpi gave 409KB filesize however, when viewed at the same screen size (about 36" diagonal) as the original 1.8MB, there was severe pixelation.
          Samt
          SamT
          1. ggt1957 | Jan 05, 2005 05:07am | #24
            I think you guys are making a mountain out of a mole hill. They ask for a simple request to supply pictures and we're off on tangents about BIGGER [??!!] file sizes in uncompressible bitmap format. Every digital camera made today is capable of saving pictures in jpg format with highly acceptable quality below 400k file size. Folks, when in doubt, read the manual, and experiment a bit before complaining about a restiction of 5 megs.
          2. JohnT8 | Jan 05, 2005 09:59pm | #32
            Hi Graham, welcome to BreakTime if you're new.  In this case we're talking about blowing up a picture of a molehill to make it look like a mountain ;)
            As I suggested to Mike, go ahead and take your 40k or 400k picture and zoom it up to 1000% or so and tell me if it looks as good as the 3-6 meg original picture that the camera pumped out (assuming max resolution) at 1000%.
            Granted, a 40-400k picture can look grand on a 17" monitor, but it doesn't always translate to 61" quite so well.
            Between the people emailing and snail-mailing, hopefully they'll get enough good pics.  And even if some of the pics are a bit small, they could always collage them or just stick them in next to text or some such.
            Edited 1/5/2005 1:59 pm ET by JohnT8
        2. JohnT8 | Jan 04, 2005 12:30am | #8
          I'm with SamT on this one.  And the way you've got it setup now, you're fighting an uphill battle.   Some of the folks who are going to have the real "wow" projects aren't the ones who have the knowledge to play a lot with picture file size or play with various compression programs.  Just ask Rez about that ;)
          Most dig cameras I've stumbled across (just regular digitals, not professional setups) use JPG as their format, so that 2.8 meg file is already compressed, so it would be a major job to reduce them without reducing the picture size or quality.  And it sounds like you want as big a picture as possible....so you really want the 3meg files.
          Which means you need to make it a downhill process.  Just give them someplace they can dump the pics, whatever the size...  As it is, your dial-up'ers are gonna have to sit there about 5 mins per meg.  And I'm sure they'd like to help you out, but they might start wondering if they really want to spend the whole night uploading pics.
          And me... well I don't have anything that qualifies as "fine homebuilding".  Now let me know if you want something on crappy 'muddling.  ;)
          Edited 1/3/2005 4:31 pm ET by JohnT8
  2. JohnT8 | Jan 03, 2005 08:48pm | #3
    You really have a lot of good pictures to choose from.  You could spend 20 mins just on Stan Foster's stair projects.   And greencu has had some neat projects.  And about 50 other folks.
    1. Woodbutcher | Jan 03, 2005 09:35pm | #5
      I really gotta figure out someday how to send photos !
      1. rez | Jan 03, 2005 09:41pm | #6
        24441.1 is one old thread that contains a lot of data regarding Irfanview.
        You could use the search function with 'irfanview' typed in. It will take you to other threads  discussing different questions regarding sending and downsizing.
        Cheers
        JeffBuck | Jan 04, 2005 12:59am | #9
        "I really gotta figure out someday how to send photos ! "
        I was thinking I gotta figure out how to build nice stuff!
        Jeff  Buck Construction
           Artistry in Carpentry
                Pgh, PA
  3. MikeSmith | Jan 04, 2005 01:08am | #10
    mark.. why don't you just download the ones in the photo folder you like..
    as far as i know ... they become your property anyway , right ?
      JeffBuck | Jan 04, 2005 01:13am | #11
      That's what I was thinking ....
      I post my fav stuff anyways ....
      Have at it.
              Pgh, PA
      1. MikeSmith | Jan 04, 2005 01:19am | #12
        hey "bucky".. did ya  figger out who you gotta go thru to get to us yet ?
        i haven't seen the match -ups yetMike Smith Rhode Island : Design / Build / Repair / Restore
    2. JohnT8 | Jan 04, 2005 01:29am | #13
      If you mean the ones people have uploaded to BT? They wouldn't work for what he wants.  Those 50k pictures work well when posting them to a BT thread where they display 6"x6", but if you super-size them to 61", they would look grainy as heck.
      If you don't believe me, view a 50k picture file in whatever image program you like.  Then zoom it up to about 1000%.  She ain't gonna be crystal clear any more.
      But what they could do is find the pics they like and then contact the people who posted them to get the original sized (big) pics.
      Edited 1/3/2005 5:30 pm ET by JohnT8
  4. calvin | Jan 04, 2005 02:20am | #14
    Mark, what if I sent you a cd with pics of my work worth looking at.  At original 3.1 mp taken size at the best resolution........
    Would you be able to do something with it?
    remember, speak slowly, I'm a dumb carpenter.
    Quittin' Time
      EricPaulson | Jan 04, 2005 02:39am | #15
      Ya beat me to it.........just what I was thinkin.
      Why not just mail a cd to the office?
      EricI Love A Hand That Meets My Own,
      1. calvin | Jan 04, 2005 03:10am | #16
        Sure would be easier than trying to figure out how to do what they suggest (which confuses the #### outta me)...........course then again, what will this idea do to their handling it on the other end?
        Now, how do we get entered into the drawing w/o attending?Remodeling Contractor just outside the Glass City.
        Quittin' Time
          SamT | Jan 04, 2005 04:23am | #18
          I second the question.
          SamT
      SamT | Jan 04, 2005 04:23am | #17
      I second the motion.
      SamT
    RichBeckman | Jan 04, 2005 05:06am | #19
    Mark,
    When you first brought this up in the other thread, you said we could send you the actual physical photos via the U.S. Postal Service (I believe it is still functioning).
    Is this still true??
    Rich Beckman
    Another day, another tool.
      SYSOP | Jan 04, 2005 05:49pm | #20
      OK let me try and answer all of the questions together here in one response.
      Images on CD: YES YES YES sending the original Hi Res Pics on a Cd would be the absolute best way. Please keep in mind that our Deadline for this is Jan. 24th which is the main reason we did not ask for this mthod originally.
      JPG Files via email: If you can compress a file without loosing any resolution then send them via email even if it means only 1 per email. If you have the abilty to compress a file then please do so. Keep in mind the bigger the better. Also please do them as Attachments not embedded in the email.
      Printed Images: Yes they can also be sent to us through snail mail
      The images that are posted in Breaktime would not be hi enough resolution to use for what we want (as pointed out)
      Email them to [email protected] or snail mail them to Dan Morrison, Fine Homebuilding, 101 South Main Street Newtown, CT 06470
      So send away. -MarkSYSOP[email protected]
        Dinosaur | Jan 05, 2005 05:56am | #26
        Hey Mark--
        What about on-screen credit for the pix? Are you going to overlay each photo with the name & contact info of the builder?
        I mean, do we have to take the blame, too???
        Yah, yah, I'll burn a CD tomorrow and snail it to ya. I'm a dial-upper. Please sign the legalese included and I'll pass any comments on to Luka who has appointed himself my agent although he doesn't know it yet....Dinosaur
          Dinosaur | Jan 05, 2005 06:00am | #27
          One serious suggestion, though: Why don't you go through the stuff already uploaded to BT's server and e-mail the owners of photos that you like, asking for full-format versions of those specific photos? Save both you and us a lot of bandwidth and licking little sticky pieces of paper....Dinosaur
            SYSOP | Jan 07, 2005 04:50pm | #34
            I've been doing that some already. And yes we are planning on putting the info on the pic as long as it is supplied to us.SYSOP[email protected]
            Dinosaur | Jan 08, 2005 02:21am | #35
            Okay I'll send ya the glass block shower and a few other choice ones.  Do you want finished only or in-progress stuff as well?
             Dinosaur
            SYSOP | Jan 08, 2005 07:08pm | #36
            What ever you got send them along... -MSYSOP[email protected]
            Dinosaur | Jan 09, 2005 05:46am | #37
            Burning away....
             Dinosaur
      2. mizshredder2 | Jan 09, 2005 06:53am | #38
        Well, what about this option:  folks upload their jpgs on a  free web pic site like  "OFOTO..." or one of the other free web sites for hosting pics.
        Then (and this is how OFOTO... works; while you're at your web hosted photo album, enter email of someone you're giving rights to view/download and that extends them electronic "invite" and access.  So SYSOPS could electronically view them and grab them right off the web.
        Also (and mebbe there's emails going on to this effect apart and off the Forum but...) I KNOW some BTers have their own websites...so could just steer FHB to those too.Vini, Vidi, Vino!  I came, I saw, I wine!
          Sphere | Jan 09, 2005 07:38pm | #39
          FWIW...I think OPHOTO can be a dangerous thing, my AV and spamminator really hate it..I dunno what's the real deal tho, have not really took the time to find out what it might be attempting.But, if it works OK for you..go for it.
          Watch out for the edges, it's really fast out there...
          1. mizshredder2 | Jan 09, 2005 08:25pm | #40
            OFOTO has been working great for me, friends, relatives for some time now.  Posted my Sept SA trip photos (all 200+ of them) on there so could readily and easily share them with friends and family across the nation, etc.  Ditto for thanksgiving pics, and now XMAS trip pics too.  Not having any problems with it.  Sorry to hear you are?were?
            I'm running Adware and Spybot on my home PC, in continuous update mode.  Not having any problems at all...Vini, Vidi, Vino!  I came, I saw, I wine!
            Sphere | Jan 09, 2005 08:31pm | #41
            Thanks, thats good news..probly the AOL from hell messing with stuff.I know ya don't wanna know how bad THAT is..LOLBe well..and ofoto'ing..
            SYSOP | Jan 14, 2005 04:30pm | #42
            OK folks the time is running short! Lets get those pictures in so that we can show off your best work... -M
            Edited 1/14/2005 11:00 am ET by SYSOP
      bobl | Jan 04, 2005 05:53pm | #21
      "the U.S. Postal Service (I believe it is still functioning).Is this still true??"Yes, the post office is still functioning.(don't get mad at me, Doug made me do it) edited per 24bobl Volo, non valeoBaloney detecter
      Edited 1/5/2005 1:02 pm ET by bobl
      1. Piffin | Jan 04, 2005 08:07pm | #22
        Just barely. A customer sent me a check via their "Priority Postage" from denver on tuesday before I left on vacation, sure it would be heere by Saturday so I could deposit it before leaving.It arrived the following wednesday at my POThe Pony Express used to cross this continent faster than many of the snail mails I have gotten from out west.
        RichBeckman | Jan 05, 2005 03:13am | #23
        "(don't get mad at me, Luka made me do it)"I think you have it wrong. We are supposed to blame Luka anytime we suspect that someone has been reporting rule violations to the moderators.I thought everything else was Doug's fault.Rich BeckmanAnother day, another tool.
          Luka | Jan 05, 2005 05:32am | #25
          That's all right, Rich.I told on Bobl for wrongly accusing me.;)
          The person you offend today, may have been your best friend tomorrow
        2. Recko | Jan 05, 2005 08:06pm | #28
          What???Now what the h@ll did I do now???"My mother failed to see the irony in calling me a sonofabitch" - Jack Nicholsen
            RichBeckman | Jan 05, 2005 09:26pm | #29
            "Now what the h@ll did I do now???"I'm probably referring to a different Doug (and a long time ago). There's two or three Dougs on the board and I have trouble differentiating between you (that's a reflection on me...).At one point Doug advertised as willing to take the blame for whatever as long as proper compensation was made. I believe many of us have "checks in the mail" to him. The Postal Service is slow indeed.Rich BeckmanAnother day, another tool.
          2. DougU | Jan 05, 2005 09:53pm | #30
            Rich
            I wasn't the Doug that advertised that I would take the "blame" for a fee, nor was I one of the Dougs that was offended by any comments.
            But, assuming that some of those checks that you are referring to will inadvertently get sent to me by mistake I would like to thank you in advance.
          3. MikeSmith | Jan 05, 2005 09:55pm | #31
            the sin eater was hubcap..
             this one is recko... and he's got enough  problems without loading him up with shouldering other burdens..
             his golf game sucks  for one thing
            hubcaps is pretty good from what  i hearMike Smith Rhode Island : Design / Build / Repair / Restore
            RichBeckman | Jan 06, 2005 01:59am | #33
            Hubcap!! Of course. Can't believe I didn't remember that!!But hasn't hubcap posted as Doug more recently??And now Recko posts as Doug.I haven't met them, and then they go changing the name they post under, and there's so many Dougs....I just can't cope!!Rich BeckmanAnother day, another tool.
          5. Recko | Jan 14, 2005 08:58pm | #43
            Hey Mike!!!My golf game sucks......MY GOLF GAME SUCKS!!!!!???!!!Anytime yer ready, pal...name the course!!!BTW, I plan on calling youse soon re: the door I want to install. Prolly not this weekend, but the next."My mother failed to see the irony in calling me a sonofabitch" - Jack Nicholsen
          6. Recko | Jan 14, 2005 09:00pm | #44
            And for the uninformed...I'm the only DOUG that matters here!!! LOL!!!"My mother failed to see the irony in calling me a sonofabitch" - Jack Nicholsen
          7. MikeSmith | Jan 14, 2005 09:11pm | #46
            hey doug.. you do know you can change your posting name to recko don't you ?
            after all, there is only ONE reckoMike Smith Rhode Island : Design / Build / Repair / Restore
          8. MikeSmith | Jan 14, 2005 09:09pm | #45
            gimme an email  and i'll tell you when a good time to call is
            mfsmith1    AT     cox.netMike Smith Rhode Island : Design / Build / Repair / Restore
