Can’t Find Hardware
| Posted in General Discussion on June 1, 2001 08:38am
Architect seeking hardware for barn-style doors. I’ve got a pair of sliding doors that I want to mount with visible wheels onto a pole. Sounds easy enough, but i don’t even know where to begin looking. Any info will be appreciated. Links, Websites, Catalogs, Pic’s are very helpful.
To the smartest consultant,
Thank you!
  1. Mongo_ | May 25, 2001 10:07pm | #1
    Do you want to mount your sliders to a "pole" (vertical?) or to a pipe mounted horizontally to be used as a rail?
    Here's one link. Not the best for fancy items, but they have the basics.
    1. Ed_Gregg | May 26, 2001 12:25am | #2
      *Sliding barn doors are great - on barns. I have several but be aware that the doors just hang from a track mounted above the doors. They are not sealed from the weather and if they break loose from their side housing, can blow off in the wind. Farm supply houses - Tractor Supply, Farm and Country and Southern States are examples - all carry barn door hardware. They have web sites. Also, do a search on the web - I think National is one manufacturer. Whenever I have the opportunity, I am changing my doors over to strap hinges mounted on pintels - a much more secure approach.
      1. Alan_Jay_Berkowitz | May 26, 2001 11:23am | #3
        *National has what you want....www.natman.comHenderson (out of Great Britain) also has some. It is distributed out of Atlanta. Check your local hardware suppliers.Good luck
        1. Jeff_Clarke_ | May 27, 2001 12:29am | #4
          *Architect with hot link - click here - You must have Adobe (these are PDF catalog pages from Richards-Wilcox).Best wishes -Jeff
          1. dzmodelman_ | Jun 01, 2001 08:38pm | #5
            *thanks to all who replied. i found something that is similar to what 'tractor supply' has from mcmaster-carr.you guys deserve a percentage as consultants!thanks again,-david
  2. David_Zerykier | Jun 01, 2001 08:38pm | #6
    Architect seeking hardware for barn-style doors. I've got a pair of sliding doors that I want to mount with visible wheels onto a pole. Sounds easy enough, but i don't even know where to begin looking. Any info will be appreciated. Links, Websites, Catalogs, Pic's are very helpful.
    Thank you!
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
