what’s the proper way to make a deck water tight at the walls.
It’s been a few years since I’ve framed a deck of this type , But I seem to recall using 1 1/2″ cant strip then the torch on was applied going up the wall about 6″.
asking because, the deck I’m dealing with (repair – leak job) had a membrane ( not torch on) go up wall then wall flashing come down over top, with no cant strip involved.
both ways work.. cant strip gets the water moving away faster
sometimes cant strip looks awkward
Thanks for response...one correction...the flashing went under the deck memebrane ( which I found out was vinyl).
I repaired the deck today corecting some slope issues, and determined that the flashing with deck will look the best. and worked well with the deck previously. with the problems being with the existing drain and the slope as mentioned.
