It’s time to broaden my horizons. I’m remodeling my bathroom and I must move the crapper. I’m running 3″ PVC. I’ve noticed that it’s common out here to use a 4″ closet flange connected to an elbow that tapers from 4″ to 3″. Is this neccessary? Can’t a 3″ flange and elbow suffice? Am I missing some sort of weird fluid dymanics here? And while I’m at it, what about the flange? Flush with the finish floor or setting upon it?
Ford Motor Company slashes prices for some F-150 Lightning models to stimulate demand for electric vehicles (EVs).
I am one too! So unless it is some weird local code there is no reason a 3 inch would not work the outlet at the stool bottom is only 2" diameter. What you might be looking at sounds like a street ell which is slip joint one side and pipe diameter the other. The flange may be 4" out side 3" inside diameter so it could fit into a 4" coupling or a 3" pipe fits inside it.
Wallyo
Edited 3/31/2008 10:20 pm ET by wallyo
