I’m having trouble with my cast iron radiators’ paint peeling off. The first two units on the loop continue to peel no matter what I do to them. Is this because the heat is too hot at the beginning of the loop? Does anyone have tips for stripping the old paint and applying the new? Is there a special paint I should be using? Greg E.
I'm in the middle of restoring a dozen rads. I sent them to a metal cleaner who sandblasted them and I'm painting them with automotive paint. The paint is rudely expensive but looks great and should last forever.
A friend has had good experience with painting Circa(sp?) on rads and covering them up overnight. He claims the paint just falls off after that.
By the way, I heard that you can buy radiator paint brushes that reaches inside the rungs.
Good luck
Paul
*Greg:Removing the paint, first obvious step can be chemical, physical (blasting) or have them burned off and pressure washed. Look in the yellow pages under paint stripping, I have had success with burnoff, it turns the paint into an ash. But once either method is used work fast due to rust, it can start in a few hours.I have powder coated radiators with good results, again check yellow pages. Jeff E.
I'm having trouble with my cast iron radiators' paint peeling off. The first two units on the loop continue to peel no matter what I do to them. Is this because the heat is too hot at the beginning of the loop? Does anyone have tips for stripping the old paint and applying the new? Is there a special paint I should be using? Greg E.
