Cast iron waste lines
| Posted in General Discussion on January 13, 2005 06:35am
I am building a two story house with 2 bathrooms over the living room and dining room.  I don’t want to interupt our dinners with the sound of water sloshing down the drain above.  So, I plan on using 3″ cast iron for the waste stacks in the wall to the crawl space but wonder how far “up stream” I need to use cast iron.
Foxtrot Kilo
  1. budreaux | Jan 13, 2005 06:49am | #1
    I have PVC horizontal lines and you can hear them.  Wish I had iron put in.
    IMERC | Jan 13, 2005 06:53am | #2
    might as well as go all the way...
    insulate with foam while yer at it or put them in a sound wall... or all three..
    WOW!!!   What a Ride!
  3. Bruce | Jan 13, 2005 05:13pm | #3
    You need to start right at the fixture and carry the cast through the living area.  You will STILL hear a flushing toilet, but at a greatly reduced sound level.  Sound batt insulation doesn't help much; I can vouch for that.  Next time, I would use spray foam all around the cast as well.
    The High Desert Group LLC
  4. MJLonigro | Jan 13, 2005 11:19pm | #4
    Contact a supplier who handles commercial grade materials (metal studs, drywall, etc.) They sell a sound deadening batt material that is design to go in between metal studs. The batts are 4' long and dense..
    We use them in commercial offices where privacy is key...work great...
The Trump Administration Wants to Eliminate the Energy Star Program
The end of this program will likely lead to higher energy bills and fewer business opportunities for the American people.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
