ceiling fan noise
| Posted in Energy, Heating & Insulation on April 14, 2007 05:56am
my ceiling fan makes a clicking sound. it don’t do it all the time. it will start clicking for 5 to 15 sec in a random pattern. is it the motor? brushes? does the ceiling fan need replacing? the house was built in 1999. we have only lived here a year and it has done it the whole time. thanks
  1. rez | Apr 14, 2007 11:12pm | #1
    Greetings mtn,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    Parolee # 53804
  2. IdahoDon | Apr 14, 2007 11:34pm | #2
    Is it well balanced?  There was a fan in my mother's house that made a clicking noise, which was actually a "squeak" from the unbalanced fan moving in the mount.
    BillHartmann | Apr 14, 2007 11:42pm | #3
    I would check all of the screws that attach the brackets to the motor and the blades to the fan.
    If it is not that suspect that the either the mount to the ceiling is loose or the box it'self is loose or nor most likely is not a ceiling fan box and mount.
    maddog3 | Apr 15, 2007 01:35am | #4
    yeah tighten everything ,
    watch the chains that dangle from the switches...for movement
    tighten any screws on the light kit ,
    and then balance the fan..
    or run it at a lower speed
    , wer ist jetzt der Idiot ?
    1. guyatwork | Apr 15, 2007 06:03am | #5
      is there a light kit? Mine has a rattle and all i do is touch the light kit and it quits. One of these days I'll dig into it more and figure out what.
        maddog3 | Apr 15, 2007 06:18am | #6
        probably the little screws that tighten onto the glass globes or trims ...I used some 3M high temp fiberglass tape once on a light ..the stuff is white .I also have never tried to balance a fan, unless the wobble was excessive .
        ., wer ist jetzt der Idiot ?
        1. guyatwork | Apr 16, 2007 05:14am | #7
          yea those balance kits are a waste of time. ive never gotten them to work for me. Duct tape and pennies always works for me.
          Thanks for the hint. I happen to have some of that stuff from a recent project.
          Matt
  • Fine Homebuilding's Author Guidelines
