After reading many discussions on cells, I have made the plunge into 250 bales of cells. Even my 6 year old could pack a bale. An earlier discussion discussed netting on walls. Does anyone see a problem with using the BIBS Isomesh on the walls? I expected a 1/4″ mesh, but this is semi-solid but breathable, I think. You can faintly see through it, but it sure is strong (and expensive). Thoughts?
Keeping HVAC systems within the conditioned enclosure can be tough without a basement; one option is to use plenum trusses for the roof, which offer a space for equipment and ductwork.
After reading many discussions on cells, I have made the plunge into 250 bales of cells. Even my 6 year old could pack a bale. An earlier discussion discussed netting on walls. Does anyone see a problem with using the BIBS Isomesh on the walls? I expected a 1/4" mesh, but this is semi-solid but breathable, I think. You can faintly see through it, but it sure is strong (and expensive). Thoughts?
