How critical is the 1/8″ gap between cement backer boards? In a thin-set application, won’t this space be filled with thin-set and be rigid anyway?
Greetings tu,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
another "bump"
Dave
I suspect that the gap provides space for the thinset to fill in and make everything rigid.
Are you supposed to do that? I never did the gap thing and never had a problem with it.
Martin
Yeah says the mfg. But glad to hear I won't be the only one.Break.
Thanks for the bumps.
I second what Dan said in post #4.Bill
or I...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
When in doubt I try to follow the manu's specs.
Sometimes they have something worthwhile to say. :o)
Which is more than you can say for here.
My understanding is that you leave the gap so that you get a better bond with the fiberglass tape and the thinset.
