Cement board underlayment on 1×8 subflr
eddie48 | Posted in Construction Techniques on February 21, 2008 09:35am
Any thoughts on installing 1/2″ cementboard underlayment on existing 1×8 diagonal floor sheathing? We plan to glue and screw the material right over the sheathing after refastening the sheathing with screws. The sheathing is gapped anywhere from 1/4″ to 3/4″ on 2×10’s at 16″ o.c. Ceramic tile (1/4″) will be installed on the cement board in a standard setting bed. Anyone out there had any negative experience doing this. I don’t have any reservation but want to assure the homeowner.
Also, we have had some discussion in the office regarding the pros and cons of using hardibacker/durock vs. Wonderboard. Anyone care to weigh in?
  1. rlrefalo | Feb 21, 2008 09:44pm | #1
    In my experience this is a marginal installation, although some guys have no problems. Tile council rec's 1 1/4 inch structural. Backer board is not structural.  What about a mud bed?  If you don't have the height, I would go with 1/2 inch underlay grade plywood, then your backer.
  2. kbd | Feb 21, 2008 10:45pm | #2
    My two cents. 1/4 inch floor tile? Are you sure they are floor rated. I have never seen ceramic 1/4" tile for a floor. I would go 1/2 plywood, 1/4 or 3/8 inch backerboard and 1/2 inch tile. use wood or marble transition. This will hold up fine.
    Edited 2/21/2008 2:46 pm ET by kbd
    1. Piffin | Feb 22, 2008 01:18am | #5
      I was wondering about that thickness myself. Maybe a sheet mosaic pattern- sometimes is a quarter inch
      1. eddie48 | Feb 22, 2008 05:44pm | #6
        My bad it is 1/2" x 12 x 12, and we are underlaying the cement board. Thanks for the help.
      2. kbd | Feb 22, 2008 09:26pm | #9
        I forgot about those,  the ones attached to the mesh are about a 1/4 inch. I was worried he was using the wall 4x4s on the floor.
  3. pgproject | Feb 22, 2008 01:14am | #3
    http://www.johnbridge.com/vbulletin/index.php
  4. Piffin | Feb 22, 2008 01:17am | #4
    I would be planning to glue and screw some plywood underlayment first, then the cement board
    DDay | Feb 22, 2008 05:52pm | #7
    Add 1/2" plywood and use Ditra under the tile. I would use Ditra regardless but for your case, you'll also benefit from the 1/8" thickness of the Ditra. Cement board is a poor choice in any situation, Ditra and some of the other products protect against cracking, are MUCH easier to install, cost the same and can be used with kerdi to get a completely waterproof floor.
  6. Jim_Allen | Feb 22, 2008 08:21pm | #8
    "Dry pack" it.
PVC for a Rot-Proof Fence
Built with rot-proof material with traditional tools and techniques, this classic border is engineered to never sag.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
