please don’t use plywood it stinks it’s to flexible especially in the laundryroom try using backerboards there great easy to use and last for ever.
please don't use plywood it stinks it's to flexible especially in the laundryroom try using backerboards there great easy to use and last for ever.
Backer board will only be as stiff as the floor underrneath.
*Cross bridging will help each joist share a bit of its load with its neighbors, but it won't do anything for flexing of the sub-floor between the joists.Adding the extra joists would probably do the most good to prevent sub-floor flex. On top of that, going to 3/4 plywood, installed with plenty of screws, should give you a pretty stiff floor. Don't count on the backerboard for any resistance to flexing. It will mainly isolate the tiles from lateral expansion and contraction of the sub-floor with changes in humidity. If height build-up is a big constraint, go for thinner backerboard and thicker plywood. If you could live with the height, two layers of plywood glued together would give you a remarkably stiff floor under the backerboard. Add the extra joists and you could invite the whole neighborhood in for a foot-stmpin' square dance.
*D, go with the ply underlay and add the joists, as suggested,yes there is a thinset for ply it's called flex-i-bond, can't think of the maker right now, but you should be able to find, one thing DON"T use an additive with the flex-i-bond , it's already there, Good Luck! Geoff
Retrofitting ceramic tile in a 5x5 laundry room. After pulling up vinyl tile and underlayment I find that sub floor is only 1/2 ply. MIGHT be able to add 1/4 underlayment on top of that and match level of adjoining floor. Lowering joists is not an option. I have access below from crawl space.
QUESTIONS: Will cross bridging between joists below be sufficient to stop flex or should I also put a layer of 3/4 ply under there?
Are there modified thinsets that have some degre of flex to them?
TIA
*If you have access to the subfloor below, consider adding joists to cut the spacing in half. ie from 16 to 8 inch centers etc. This will reduce the load on each joist by half and cut the plywood span to half. 1/2" plywood spaning 8" should be fine. How are the plywood edges handled. I have never seen 1/2" t&g, so are they blocked. If the plywood is not t&g the edges will need to be blocked.
