I am tiling a shower, 3 walls and then there is the door. On another forum I was told that the two corners at the back, where the walls meet should technically not be grouted but should have caulk in the corners. I guess to reduce the stresses that can cause cracking.
Opinions? whats most commonly done?
Keeping HVAC systems within the conditioned enclosure can be tough without a basement; one option is to use plenum trusses for the roof, which offer a space for equipment and ductwork.
You can easily start WWIII with this question.
I never realized it was an issue/ difference of opinion thing. Must be, like caulking the bottom of the tile at the tub flange or leaving it open. Amazes me that someone has not "solved/resolved these questions years ago,
Actually, its less of a controversy than some might let on.For a "mud man" -- someone who makes his living by building dry-pack mortar beds and walls, the question is almost moot. Those guys can build a shower stall that is strong enough that there is no flex, not even at the corners.but for most tilers, the use of backerboard is the rule. And the backerboard is hung on the studs, which may or may not be stiif enough, or flat enough. In such stalls, there is corner flex, which could crack the corner grout.So use caulk -- like another said, there's color-matched stuff available.
I won't be laughing at the lies when I'm gone,
And I can't question how or when or why when I'm gone;
I can't live proud enough to die when I'm gone,
So I guess I'll have to do it while I'm here. (Phil Ochs)
If this is lightweight frame construction, like cement board over wood framing, then caulking is your best bet. If you grouted the corners, as the walls flex the grouted corners could crack whereas the caulk will flex.
You can buy color and texture matched caulk so the caulk color/texture matches your grout.
If you have floated mud walls with reinforced corners, then you can grout.
If you go to a real tile shop you can buy sanded and unsanded caulk in colors to match the grout. The theory is that the most likely place for the shower walls to crack is in the insode corners, so you caulk it with a meterial that has a little flex. That's what I do. Others don't agree.
I use color matched, sanded or unsanded, caulk to match the grout.
Jim
